MJL316
Dec 31, 2020Initiate
ORBI App not connecting to router
After downloading IOS 14 my Orbi App will not connect to ORBI router, even twith rying anywhere access connection. Keep getting errors that my wifi is off and local area network is off, which is not ...
Jul 25, 2021Guru - Experienced User
What FW is loaded on the Orbi system?
I'd try a full factory reset on the RBR with a wired PC and web browser. Setup using the web browser mentod. Be sure to write down all important information for safe keeping. Once the RBR is setup again, try the Orbi app. You might uninstall the app then re-install it. Also try the app on a different device as well.
Mikey32235
Jul 26, 2021Tutor
It’s now working! Thank you!
- FURRYe38Jul 26, 2021Guru - Experienced User
Enjoy.:smileywink:
Mikey32235 wrote:
It’s now working! Thank you! - ansarim786Oct 02, 2021Aspirant
Did it work because you did a factory reset? I have the same problem - all my connections work except for 1 device. I played around with the Orbi app, not sure what I did in the Devices section and then 1 connection (fireTV stick - one of many in my house) and now the Orbi app does not work either.
I am going to explore the factory reset option. But, wanted to confirm before I take such a drastic measure to fix my issue.
- FURRYe38Oct 04, 2021Guru - Experienced User
Something to try out and see.
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
