MJL316
Dec 31, 2020Initiate
ORBI App not connecting to router
After downloading IOS 14 my Orbi App will not connect to ORBI router, even twith rying anywhere access connection. Keep getting errors that my wifi is off and local area network is off, which is not ...
Mikey32235
Jul 26, 2021Tutor
It’s now working! Thank you!
Jul 26, 2021Guru - Experienced User
Enjoy.:smileywink:
