MJL316
Dec 31, 2020Initiate
ORBI App not connecting to router
After downloading IOS 14 my Orbi App will not connect to ORBI router, even twith rying anywhere access connection. Keep getting errors that my wifi is off and local area network is off, which is not ...
ansarim786
Oct 02, 2021Aspirant
Did it work because you did a factory reset? I have the same problem - all my connections work except for 1 device. I played around with the Orbi app, not sure what I did in the Devices section and then 1 connection (fireTV stick - one of many in my house) and now the Orbi app does not work either.
I am going to explore the factory reset option. But, wanted to confirm before I take such a drastic measure to fix my issue.
Oct 04, 2021Guru - Experienced User
Something to try out and see.
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
