csbmr
Dec 18, 2021Aspirant
orbi app only showing 1 of 2 separate routers
I have two routers, Orbi RBR50 and an Orbi Pro Wifi 6 Mini AX1800. When I look at the Orbi app on my iphone I only see the RBR50 which is remote. The Orbi Pro router (which is the router I am curr...
Dec 18, 2021Guru - Experienced User
Orbi app doesn't support Orbi Pro. You'll need the Insight app for Orbi Pro.
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
