mediabiz
Mar 13, 2019Aspirant
Orbi App Pause/Resume function
Hi all,
Hoping someone can give me a hand with this.
Got the Orbi RBR50 (Main + Satellite) and overall, works very well. Installed the Orbi app (latest version) on both IOS and Android devices an...
- Mar 13, 2019If you can’t change the switch slide to the pause position then that tells me that your Orbi can be in AP Mode, is it?
CrimpOn
Mar 13, 2019Guru - Experienced User
This depends on which version of firmware is in your Orbi. The "current" firmware apparently does not handle device blocking correctly. The 2.3.0.32 version which is available for manual installation appears to do better. I recommend searching the community forum.
(I do not do this myself.)
