mediabiz
Mar 13, 2019Aspirant
Orbi App Pause/Resume function
Hi all,
Hoping someone can give me a hand with this.
Got the Orbi RBR50 (Main + Satellite) and overall, works very well. Installed the Orbi app (latest version) on both IOS and Android devices an...
- Mar 13, 2019If you can’t change the switch slide to the pause position then that tells me that your Orbi can be in AP Mode, is it?
ekhalil
Mar 13, 2019Master
mediabiz
Mar 14, 2019Aspirant
You're a legend! I reckon that's what it will be. I have to use the Orbi in AP mode running off my internet providers crappy router. I've got no choice but to use theirs as they wont give me the VOIP password to use on another router but at least I can turn off the WiFi and use the Orbi as an AP.
Great, thanks for your help, disappointing but at least I know what the issue is now.
