wdanner
Jul 13, 2020Tutor
ORBI app shows 100+ speed on iPhone, but MacBook pro speed test is far slower. How can this be?
Latest firmware confirmed. Getting fabulous speed reported on the Orbi app, low latency, low jitter. Putting iPhone and MacBook Pro side by side, results are a small fraction of the speed reported ...
Jul 13, 2020Guru - Experienced User
What is the connection rate on the iphone and mac book pro when connected to the RBR? They should read around 866Mbps when near the RBR.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Are you using Ooklas installable speed test app on the Mac?
What OSX version is loaded on the Mac?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
