Nansterz
Apr 20, 2020Guide
Orbi App Speed Test vs Actual
Last week, we noticed a significant drop in home network speeds. I did the standard troubleshooting, rebooted the modem, reboot the Orbi and we completely lost the internet - I couldn't get a dynamic...
- Apr 21, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Is this the CM modem you listed in you product list? You using the RBR20?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).You may want to update FW if you haven't already:
Apr 22, 2020Guru - Experienced User
Try this on the RBS with v16 RBS FW at the ready:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
When the satellites are reset, wait about 5 minute. The PC will get a IP address from the satellite. the IP address will be 192.168.1.250. You can look at the network status connection properties to see what the GATEWAY IP address is to verify. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Do this for both satellites. Then factory reset and then re-sync the satellites to the RBR.
Nansterz wrote:FURRYe38.. I went ahead and performed a manual update and the speed issue appears to be resolved. I DID run into a snag during the firmware update process - I kept getting "Firmware upgrade failed. Please check your file." on the satellite (that I forgot to mention in the original post). So me being the smarty pants that I am (sarcasm), I tried a factory reset and removal of the satellite from my network. I figured that it would treat it as a brand new satellite upon adding back to the system and would auto-update the firmware. Welp, that didn't work. It recognizes it when I plug it back in and so it's stuck on 2.3.5.6. I tried to update it manually and still getting the upgrade failed error.
I did a speed test and the numbers are back to where I expect them.. I just really need to see if there's a speed difference on devices connected to the satellite and also find a way to get it to take a firmware update.
Nansterz
Apr 28, 2020Guide
By some crazy miracle, the firmware updated. I’m not sure how or why, but it did and everything has been stable.
Thank you all for your help.
- Retired_MemberApr 28, 2020
Thank you all for your help.So what version are you on now?
- NansterzApr 29, 2020Guide2.5.0.2
- FURRYe38Apr 29, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
