maks71's avatar
maks71
ORBI App takes up too much storage (5+GB ) on Android
Any idea why ORBI app takes up whopping 5+GB space on Android?   Here is the break up I get from Storage analyzer   App - 163MB, Data - 5.26GB , Cache 483K -  Total - 5.42GB   How can I reduce th...
  • maks71's avatar
    maks71
    Jun 07, 2021
    I was contacted by NG community support and was requested to participate in beta version. I did and provided fix seemed to have resolved the issue. The storage consumption is now lt 200mb.
    So the higher space consumption was related to the issue in the app.
    Hopefully NG support may already reached out to you.
    Thanks.
