biggator
Oct 08, 2020Tutor
Orbi app vs web interface - different information
So I'm trying to add another satellite to my Orbi system (currently RBK50 and one RBS50 satellite). I can get it to join via wifi backhaul, but I really would prefer ethernet from where this one is...
Oct 08, 2020Guru - Experienced User
Be sure to sync the RBS to the RBR wirelessly first to make sure it syncs.
Be sure the FW is up to date or using the same version number as seen on your RBR.
biggator
Oct 08, 2020Tutor
They are all on FW v2.5.2.4 - all synced wirelessly, but will not connect via ethernet.
I've tried two different switches (read somewhere that 'green' enabled switches had issues) - going to try to get it to connect directly to the RBR and see if it will work that way, then move it.
- FURRYe38Oct 08, 2020Guru - Experienced User
Yes some switches included Green Ethernet features which can cause problems.
What Mfr and model# switch are you using?
Also has this worked before with your switches before the FW update?
- biggatorOct 08, 2020Tutor
The area where the satellite is had a Trendnet green switch.. pulled it and tried a d-link non-green switch. Neither worked. No, it's never worked with ethernet backhaul.
- CrimpOnOct 08, 2020Guru - Experienced User
biggator wrote:going to try to get it to connect directly to the RBR and see if it will work that way, then move it.
This is a good idea. If it will not sync when connected directly to the router, "something is terribly wrong."
I do not recall reading in this post what kind of ethernet wiring is being used to connect the new satellite to the switch.
(Did I miss it?)
i.e. a purchased ethernet cable? an ethernet cable installed in the building and terminated in jacks on each end?
