biggator
Oct 08, 2020Tutor
Orbi app vs web interface - different information
So I'm trying to add another satellite to my Orbi system (currently RBK50 and one RBS50 satellite). I can get it to join via wifi backhaul, but I really would prefer ethernet from where this one is...
biggator
Oct 08, 2020Tutor
They are all on FW v2.5.2.4 - all synced wirelessly, but will not connect via ethernet.
I've tried two different switches (read somewhere that 'green' enabled switches had issues) - going to try to get it to connect directly to the RBR and see if it will work that way, then move it.
Oct 08, 2020Guru - Experienced User
Yes some switches included Green Ethernet features which can cause problems.
What Mfr and model# switch are you using?
- FURRYe38Oct 08, 2020Guru - Experienced User
Also has this worked before with your switches before the FW update?
- biggatorOct 08, 2020Tutor
The area where the satellite is had a Trendnet green switch.. pulled it and tried a d-link non-green switch. Neither worked. No, it's never worked with ethernet backhaul.
Ok, so does the RBS work if you directly connected to the back of the RBR with just a patch cable? CAT6 is recommended. After it's wireless connected, then connect the cable between the RBR and RBS. Try a different port on the back of the RBS as well.
If the RBS doesn't connect at all on wired backhaul, I would presume the RBS maybe faulty.
