OldRodz56
Sep 28, 2019Follower
Orbi app will not connect to RBR50 due to network name change
I set up the Orbi RBR50 last year. Today I am setting up the Orbi app. The Orbi app will not connect to the RBR50- possibly due to Orbi Network name change? Nothing I try seems to work. I am not ...
ekhalil
Sep 29, 2019Master
To connect using the Orbi app you need two credentials:
- Netgear Account to be able to log in to the Netgear Cloud.
- Orbi managament account (user admin and your admin password)
You need to be connected to the Orbi wifi when you connect using the app the first time. Later on you can also use the app to log in to Orbi remotely.
CrimpOn
Sep 29, 2019Guru - Experienced User
I reloaded the Orbi app on my Android phone just ow (version 2.4.8.816). When it asked for "Location Permission" it definitely was an option. One of those ominous warnings, "May experience reduced experience if location is not allowed." The app was clearly prepared to proceed without knowing location. Maybe the Apple app is different?
