bs6mjb
Dec 20, 2016Tutor
Orbi app won't login if admin password contains ;
Netgear Mods Orbi app won't login if admin password contains ; (in my case the ; was at the end of the password) The password is fine for the web interface but Orbi app fails. Might want to fix th...
bs6mjb
Dec 20, 2016Tutor
Sure....but my point was that if the regular web interface allows you to set and use the password then the Orbi app should allow the password to be used as well.
