MyOrbiGear
Jan 09, 2018Initiate
Orbi App
What’s up with the Orbi app? Why can I not access my router from outside the house. My cheap linksys could do this. My wife is having problems with the WiFi at home and I cannot help here. Why did I s...
eljarviso
Jan 09, 2018Luminary
You can use it outside your network if you've enabled remote access on your router beforehand.
- MyOrbiGearJan 09, 2018InitiateThat is not an option on my Orbi app. It says it will only connect with routers that I am connected to. So the app has to see an orbi network before it will connect. I should have an option to log into my account and then access my router. I do not see that option in the app. Thanks for your help tho.
- eljarvisoJan 09, 2018Luminary
You'll need to enable all of your features from within the WebUI located at https://orbilogin.com . You will need to do this from your home network. From here you can setup remote access.
- tagteamJan 09, 2018Virtuoso
MyOrbiGear wrote:
That is not an option on my Orbi app....I am fairly certain you need to use the Netgear genie app for your purposes; the Orbi app does not (yet) have remote functionality.
