DL68
Apr 25, 2020Aspirant
orbi app
I've set up the Orbi Whole Home Wi Fi system AC3000, and the Orbi app shows connection and all works well...except that my Roku device apps don't work. When I click on Amazon Prime Video or Disney Pl...
- Apr 25, 2020The simplest solution is to put the Orbi into Access Point (AP) mode. Use the Orbi web interface, Advanced Tab, Advanced Settings, Router/AP mode. The Orbi will reboot. Now the ATT will assign all IP addresses. Easy enough to try.
DL68
My internet service provider is AT&T-Uverse. They provided me with their brand of router/modem and its model number is NVG599. I agree this is likely a double NAT issue but I cannot figure out how to change my ATT unit to modem only and impossible to get a hold of ATT technical support. Any suggestions or other ways to fix this issue? Hard to believe I'm the only one to face this problem, as I followed all the instructions in the Orbi app setup.
CrimpOn
Apr 25, 2020Guru - Experienced User
- DL68Apr 25, 2020Aspirant
Thank you! That worked perfectly. I really wish Netgear would anticipate these issues and add a simple notification to new Orbi users of the need to go to Advanced Settings to change to the access point setting on the Orbi router when connecting via existing (in my case) AT&T router / modem. Much frustration over something that was easily fixed and should have been part of the standard set-up instructions. Oh well...
- Retired_MemberApr 30, 2020
DL68 wrote:Thank you! That worked perfectly. I really wish Netgear would anticipate these issues and add a simple notification to new Orbi users of the need to go to Advanced Settings to change to the access point setting on the Orbi router when connecting via existing (in my case) AT&T router / modem. Much frustration over something that was easily fixed and should have been part of the standard set-up instructions. Oh well...
interesting point.....I suspect like many consumer goods, NG exepcts folks to have a understanding how a home network works. This would include such things as a modem, router (one only please), extenders, etc.
The other side to the equation would be then to also have a understanding of what the consumer currently has in their home, i.e. do I already have a modem, router (ouch).
Most of the problems (outside of firmware updates) that I have seen here is in the case where folks have no idea what they currently have and/or if the Orbi will work easily with the current setup without major configurations.
- FURRYe38Apr 30, 2020Guru - Experienced User
There are installation guides and user manuals available for review.
Also https://kb.netgear.com/30186/What-is-Double-NAT
is this what you're looking for:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- Yummy571Apr 30, 2020Tutor
how doo you open the interface please?
Yummy571 wrote:how doo you open the interface please?
Log into the RBRs or modems web page with a wired PC and web browser.
For any Orbi app questions and help, please post in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
