rdabbah00
May 05, 2020Aspirant
ORBI APP
Hi my app do no show my conected devices , i unistall it and intall again and doesnt work i need to acces my orbi using my computer
May 05, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
SLK-Purdue
May 05, 2020Luminary
I suspect this is actually the SOAP problem I reported with FW 16 and not the app. The app is getting bad data.
scott
FURRYe38 wrote:Please post about this in the Orbi app forum:
Good Luck.
- rdabbah00May 05, 2020Aspirant
What you mean SOAP problem? i dont undestarnd that
- CrimpOnMay 05, 2020Guru - Experienced User
I believe SOAP refers to this:
https://searchapparchitecture.techtarget.com/definition/SOAP-Simple-Object-Access-Protocol
It's a mechanism to query the Orbi router for information. The Orbi "app" communicates with the Orbi router, asks for information, and does things with it (such as display icons, etc.)
- SLK-PurdueMay 05, 2020Luminary
Sorry. I should have provided more background. SOAP is the method that the app uses to get data from Orbi. Per my previous posts, I believe the problem is that Orbi is giving incorrect data to the app rather than an actual problem in the app. I had some issues with the new app too but I have an Excel spreadsheet that can make SOAP calls directly to Orbi. The data from Orbi is incorrect.
Scott
