dono703
Jul 14, 2017Initiate
ORBI appears twice in available WiFI on Epson Workforce 545 Printer
I have literally spent 5 hours over the last 2 nights trying to get ORBI set up right. As of now I finally have WiFi in the house, EXCEPT we cannot get the printer on-line. No matter what I name th...
dono703
It did not matter which Orbi I selected, the printer would not function. I took the advice and ran an Ethernet cable to the printer and I got it to work. Again I'm not sure what the issue is because if I unplugg satalite problem still exists. So hardwiring is a distasteful but workable solution. Waiting on new Ethernet cable to arrive as need longer.
raven_au
Jul 15, 2017Virtuoso
That's becuase those SSIDs probably aren't router and sat but are the 2.4Ghz and 5Ghz wireless on different channels. You might even see a third, that being the hidden backhaul.
Seeing the two entries is quite common in my experience.
With other routers that provide band steering on a single SSID, if you find you have a device that can't handle the steering you would just turn off the single SSID function and give each band a distinct SSID, but Orbi doesn't provide that ability.
Ian
