Jgoldsti
Nov 26, 2020Star
Orbi armor blocking wyze lock gateway setup
I tried to set my wyze lock gateway up using my orbi rbr50 with armor enabled. The setup kept failing at the stage of connecting to the wyze cloud. I finally turned off armor and the lock gateway se...
CrimpOn
Nov 26, 2020Guru - Experienced User
Jgoldsti wrote:
Is there a way to tell armor to let certain connections occur or to see connections it is blocking?every firewall I have used allows both of these capabilities.
This question is more likely to get an informed response if posted in the communit forum for the Armor product:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
My observation is that few people who watch the "general Orbi topics" forum have activated Armor. It's not that we don't want to help; we are just seriously ignorant about the product.
