Crasje
Apr 10, 2022Tutor
Orbi as access point?
Hello, i just moved house and now my Orbi router is in the basement next to the router of the i-net provider. I have network cable from the cellar to the ground floor. instead of extending m...
Apr 10, 2022Guru - Experienced User
You can connect the orbi in access point mode.
Keep in mind though that your ISP router won't "mesh" with the orbi.
You can use it in conjunction with it though. I'd set it with its own ssid and make sure its on a different wifi channel than the orbi to prevent interference.
