dip1
Sep 10, 2019Aspirant
Orbi as an access point
Hi Looking at getting an orbi system but have seen with other manufacturer systems there is a big difference in functionality when using in AP mode vs. router mode. What functionality gets lost whe...
- Sep 10, 2019
here's the list of disabled features.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
The following router features are not available (grayed out) when the router is in AP mode:
- Guest Network
- QoS
- Setup Wizard
- Port Forwarding/Port Triggering
- Remote Management
- UPnP
- IPv6
- Traffic Meter
- Parental Controls
- Block Sites
- Block Services
- VPN service
- VLAN/IPTV setup
- Internet Setup
- WAN Setup
- LAN Setup
You can stll manage the orbi with the app or the browser when in AP mode.
Sep 10, 2019Guru - Experienced User
- Guest Network
- QoS
- Setup Wizard
- Remote Management
- UPnP
- IPv6
- Traffic Meter
- Parental Controls
- Block Sites
- Block Services
- VPN service
- VLAN/IPTV setup
- Internet Setup
- WAN Setup
- LAN Setup
dip1
Thanks for pointing me to that.
Ouch....thats quite a lot non-functional.
Some understandable as not relevant.
The killer for me is no guest network.
- Fl1ntstoneSep 10, 2019Apprentice
Hi Guys,
Guest WiFi is available when the Orbi is an access point.
CheerZ
- michaelkenwardSep 11, 2019Guru - Experienced User
Indeed. The list of disabled features for Orbi is not the same as it is for routers.
See the "This article applies to:" list for that article.,
- dip1Sep 12, 2019Aspirant
Ah! Good point.
Anyone aware of a similar list for Orbi?
