Knicks1met
Feb 26, 2019Aspirant
Orbi as AP 2.4 and 5ghz
I am trying to set up the Orbi as an access point. I have my existing router as the main router with a different ssid for 2.4 and the 5ghz. When i set up the Orbi access point, what name should I give...
Knicks1met
the problem I'm having is that the connection is constantly poor. My phone or tablet will show full Wifi bars but when I try to load a webpage, the page does not load. The only way to get it working again is to turn off wifi from my device, turn it back on and then it will connect. I'm trying to figure out the best way to set up the Orbi so it does not do this.
Feb 26, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
The best way to setup Orbi is with a PC or laptop and a web browser.
