moderno's avatar
moderno
Follower
Jun 28, 2017
Orbi as wireless bridge for Mifi/Hotspot
I currently use a TP-Link N450 Access Point as a wireless bridge.  It wirelessly connects to a mifi/hotspot for internet connection and creates a network based on this connection.  The hotpost is a Verizon Wireless Jetpack 6620L.  The TP-Link N450 is a little buggy and I would prefer to eliminate it alltogether.
Can the Orbi Router wireless connect to the hotspot in the same way .. similar to a wireless bridge?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello moderno
    No Orbi can not bridge over wireless if you were able to get a Ethernet connection from the aircard to the orbi that would work.
    DarrenM
