beguna1
Apr 15, 2022Tutor
Orbi assigning 1 satellite out of range address
Router is set as DHCP server set for range of 10.0.0.2 to 10.0.0.254. There are 2 wired satellites. One is correctly assigned 10.0.0.3 but the other is assigned 192.168.1.250. All other devices ar...
- Apr 15, 2022
Even though I had rebooted the Orbi router several times and had done a factory reset of the miss-addressed satellite several times over many hours of pulling my hair last night, this morning I reset the satellite one more time and it miraculously got a new address in the right range. I have no idea why. (I have Google Fiber and the modem is just a modem. The Orbi is the only router giving out addresses on my network.) I have seen this behavior one other time on my mesh where it took about 8 hours or so for the Orbi router to give the second wired backhaul satellite a proper address. This is using latest firmware V2.7.3.22. The other wired satellite gets assigned a correct address right away. They are not daisy chained. And the satellite getting the right address first is not always the same satellite.
beguna1
Apr 15, 2022Tutor
KevinLiT
Apr 15, 2022NETGEAR Moderator
Hi beguna1,
I am happy that you were able to sort this issue out. There are times when we have to be persistent when dealing with technical anomalies. From your previous post, it looks like you have an RBK50 Orbi system.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#RBR50%20(Orbi%20Router)%20Firmware%20Version%202.7.4.24
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
(Please ensure you update the satellites first. )
Best,
Kevin
Community Team
