Juice2boost
Nov 12, 2019Follower
Orbi Assigning device to IP already Reserved
Today I went and reserved a couple of devices to an IP that way if I lose power, It will be assigned to that same IP when power is restored. Such things as my NAS and my Smart Home Hub. I signed...
michaelkenward
Nov 13, 2019Guru - Experienced User
SW_ wrote:
Yes, that would work, but it's a chore to reserve/static IP addresses for all clients on the network to avoid this problem.
Just stick with the stuff that causes problems. There can't be many Xboxes on a network.
SW_
Nov 17, 2019Prodigy
michaelkenward wrote:
SW_ wrote:Yes, that would work, but it's a chore to reserve/static IP addresses for all clients on the network to avoid this problem.
Right, that was what I did initially. Then this problem just moved to the next sticky device on my network. My observation is that if any cient goes into power saving mode, it will have this problem (connected but no Internet) with Orbi until it's rebooted, a similar problem with green switch. Instead of chasing this problem, my solution was to turn off power saving on all the clients on my network and reboot stubborn clients that don't let me turn off power saving, which fortunately are just a few.
