HazardousTim
Mar 23, 2020Star
Orbi assigning wrong DHCP IP Space
I have an odd issue where Orbi will assign some devices the wrong IP address space. My default space is 10.0.0.x and I have some devices connected wirelessly that get assigned an ip address of 192.16...
Mar 24, 2020Guru - Experienced User
If your going to use the RBR in router mode behind another router, I would make sure you place the RBRs WAN IP address it gets from the ISP router into the DMZ on the modem. Will help with NAT problems when in this kind of configuration.
HazardousTim wrote:I have an odd issue where Orbi will assign some devices the wrong IP address space. My default space is 10.0.0.x and I have some devices connected wirelessly that get assigned an ip address of 192.168.2.x. Other than assigning static IP Addresses I'm not sure how to resolve the issue.
Anyone else run into this problem?
HazardousTim
Mar 24, 2020Star
It is already getting its NAT IP address via DHCP from the AT&T Router.
FURRYe38 wrote:If your going to use the RBR in router mode behind another router, I would make sure you place the RBRs WAN IP address it gets from the ISP router into the DMZ on the modem. Will help with NAT problems when in this kind of configuration.
