zcobrausa
Nov 13, 2017Aspirant
ORBI Authenication error
I have had the RB50 router with 2 satellites for about a year and it has worked great. After the last Android update my phone loses connection and shows "authenication error occurred". I have check...
DarrenM
Nov 15, 2017Sr. NETGEAR Moderator
Have you tried to forget the orbi network on the phone and connect to it again?
DarrenM
zcobrausa
Nov 15, 2017Aspirant
I have tried that. I also tried running the phone in safe mode. Sometimes the phone will stay on the network for a couple hours and other times just a few minutes. If I turn the wifi off and then back on it will reconnect.
- DarrenMNov 16, 2017Sr. NETGEAR Moderator
what android phone are you using?
DarrenM
