rvk_ice
Jan 19, 2022Tutor
Orbi AX1800 will not connect to internet
Just purchased Orbi today, more specifically : Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350). Thing came in a package with AP (which I have just kept in the box to add later if I ever get internet...
- Jan 19, 2022
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
CrimpOn
Jan 19, 2022Guru - Experienced User
rvk_ice wrote:
Is there a difference in a WAN port and the internet port in of the Obri router?
Absolutely there is a difference. The Orbi will connect to the internet only through the WAN port.
rvk_ice
Jan 20, 2022Tutor
Agreed. But it is a bit confusing that on the Obri router there is a yellow port for input marked "internet" (not WAN). I'm familiar with a WAN port from my current router and others but wanted to get affirmation that there is no diffenece in this "internet port" from what we know as WAN.
Here's you can see the backside of the router.https://www.netgear.com/uk/home/wifi/mesh/rbk353/
- CrimpOnJan 20, 2022Guru - Experienced User
You are SO RIGHT (and I am so embarassed). Bless their little pointed heads. On the older Orbi's, the entire jack was yellow and labelled "WAN". Score for reading comprehension: zero.
