LyndB
Aug 01, 2021Aspirant
Orbi AX600 plus nighthawk ac2600 switch off wifi
Hi, I have a Nighthawk X4s Ac2600 modem/router, but lacked wifi in some parts of the house, so just installed Orbi AX6000 (2 satellites), I've changed Orbi to AP, but wifi still available from the AC...
Aug 02, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
LyndB wrote:Hi, I have a Nighthawk X4s Ac2600 modem/router, but lacked wifi in some parts of the house, so just installed Orbi AX6000 (2 satellites), I've changed Orbi to AP, but wifi still available from the AC2600. How do I switch off Wifi from this (Logging in to netgear login no longer shows Ac2600 info, only Orbi)?
Be gentle, I'm not the most technical so may be missing the obvious! :smileywink:
Many thanks
Lynda
