SwiftyD
Aug 30, 2021Tutor
Orbi AX6000 (RBK853) purchased in Singapore. Now moving to the US. Will it work?
Hi all. In Singapore I purchased the Orbi AX6000 (RBK853) router with two satellites. In the next couple of weeks I will be moving to US. Should I be bringing the Orbi with me? Are wifi networks more...
SwiftyD
Aug 30, 2021Tutor
Thanks a million CrimpOn! I feel assured the Orbi will work in the US as well. Under the Advanced Wireless Settings I am able to change the region. Thanks for the link to the power adapters as well. Cheers!
Aug 30, 2021Guru - Experienced User
Be sure to visit the Orbi AX forum for your future orbi AX needs:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck
