oxoclear
Feb 15, 2022Tutor
Orbi b locks access to wireless heating controls
I have recently set up a mesh system replacing a TP link solution. Unfortunately the Obi system blocks access to my siemens RDS110 heating controls. The device logs on to the network, no problem, bu...
Feb 15, 2022Guru - Experienced User
what modem/gateway is the router connected to?
Is the Siemens showing up in the attached devices list?
What firmware is on the orbi and satellites?
oxoclear
Feb 15, 2022Tutor
Hi The Orbi Is Connected to A Draytek Router. I Can See The Siemens Device In the DHCP table on The Draytek.
- oxoclearFeb 15, 2022Tutor
Should uld Have Added Firmwarevv2.7.3.22
- plemansFeb 15, 2022Guru - Experienced User
Is the orbi being ran in access point mode?
Or do you have the orbi's IP address entered into the Draytek's dmz?
Hi It Is Running In Ap Mode. I Have No Idea Every Word Is Starting With A Capital !
In access point mode, the dreytek is controlling everything. And if its showing up in the dhcp table its connecting back to the primary router. so I'd be looking at your dreytek for whats blocking the setup.
