DESIi1
May 02, 2017Star
Orbi backhall signal dropping to Zero
When I upgraded to the latest firmware the backhall signal started to drop to zero. It was smooth prior to the upgrade. This has to degrade performance. See below. What can be done?
Retired_Member
May 05, 2017Hi Darren,
Not Desli1, but for me:
1. Currently on 1.9.1.12 but also on the 2 or 3 previous firmwares. I do not know when it was last stable or ever, because it was dropping the first time I checked months ago.
2. Laptop and smartphones. Wired connection to desktop is solid and always full speed.
3. 1 router and 1 satellite. Issue still occured while satellite was away being RMA'd.
4. Captured with wifiAnalyzer app on smartphone and inSSIDer on laptop.
5. It occurs whether I am right beside the router or at the edge of its range. With no satellite connected, the router was still broadcasting the backhaul (no SSID) and it was constantly dropping.
- Retired_MemberMay 05, 2017
Here is my screenshot. Light blue and green are the 2.4 and 5 GHz Wi-Fi signals from the router. Orange and pink are the backhaul. Dark blue and red are the satellite signals (farther away). Thanks.
- DarrenMMay 05, 2017Sr. NETGEAR Moderator
Thanks for responding so quickly I will pass this info on.
DarrenM
- OrbiManMay 05, 2017Luminary
I will also add in my data. I have the 1 router 2 satellite. I do NOT have drop out of Internet. The above graph was taken when I was streaming supergirl from the CW website. However my backhaul does not cut to 0 but it does go down to - 110 signal which is pretty much nothing. The rest of network I did not show because of privacy reasons but they all remain good strength
- DESIi1May 08, 2017Star
Unfortunately now my satellites are also dropping to zero.
Should I contact tech support?
- DarrenMMay 10, 2017Sr. NETGEAR Moderator
Hello Desli1
Yea you may want to contact support with this.
DarrenM
