DESIi1
May 02, 2017Star
Orbi backhall signal dropping to Zero
When I upgraded to the latest firmware the backhall signal started to drop to zero. It was smooth prior to the upgrade. This has to degrade performance. See below. What can be done?
tubastank
Jun 12, 2017Apprentice
I can confirm what BobertSaget is saying...at least for the backhaul dropping and disconnects even worse. The only thing that's helped me so far is unplugging both satellites and just using the Orbi router; a solution that defeats the intended use of the system.
