DESIi1
May 02, 2017Star
Orbi backhall signal dropping to Zero
When I upgraded to the latest firmware the backhall signal started to drop to zero. It was smooth prior to the upgrade. This has to degrade performance. See below. What can be done?
Retired_Member
Jun 14, 2017Thanks st_shaw, very interesting and confusing at the same time. I wonder why different clients report the signal differently? I don't have any old Androids but I would be curious to check mine if I did.
- st_shawJun 14, 2017Master
Retired_Member I don't know either. Could be something to do with the hardware and drivers. All the hardware I've tested with so far is 802.11n dual band. That should be all thats needed though.
I've looked at wireshark a bit, but it's pretty involved and I need more time to understand the traffic.
Did you try using NETGEAR's WiFi Analytics app on your Android?
