DESIi1
May 02, 2017Star
Orbi backhall signal dropping to Zero
When I upgraded to the latest firmware the backhall signal started to drop to zero. It was smooth prior to the upgrade. This has to degrade performance. See below. What can be done?
gasongasoff
Jul 02, 2017Initiate
Any updates? Will flashing back to a prior firmware solve the issue?
peteytesting
Jul 03, 2017Hero
the issue seems to one of incorrect reading of the apps with certain wireless adapters used rather than an actual backhaul issue , rolling back fw wont help as the orbi will just roll it forward again , new fw wont be far of and should fix a lot of connectivity issues according to those in the community using the latest beta fw
