jamepc
May 04, 2021Aspirant
Orbi Backhaul Ethernet Switch
Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain l...
May 04, 2021Guru - Experienced User
How do you have the RBS and switch connected to the RBR?
How long after you connect the RBS to the switch are you waiting for the RBS to sync fully?
jamepc wrote:Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain local network conection).
I use an unmanaged Netgear switch but have other devises on the same switch. Do the staelites need their own switch? Or can other devises be on the switch too?
Thankyou,
Jamie
