jamepc
May 04, 2021Aspirant
Orbi Backhaul Ethernet Switch
Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain l...
CrimpOn
May 04, 2021Guru - Experienced User
jamepc wrote:Currently when I connect the RBS50 satelites via ethernet to a switch that has other devices, my network goes crazy. I loose Wifi on some devices and others I lose internet connection (but maintain local network conection).
I use an unmanaged Netgear switch but have other devices on the same switch. Do the staelites need their own switch? Or can other devices be on the switch too?
Is "currently" significant? i.e. was this configuration working before?
Yes, other devices can be on the same switch as the satellite.
Is it correct to assume that the swtich comes after the Orbi, i.e.::
Internet modem port connected to WAN (yellow) port on Orbi.
Orbi LAN port connected to switch.
Satellite and other devices connected to switch.
- plemansMay 04, 2021Guru - Experienced User
If your vonage devices aren't connected, do you have issues with other devices connected?
I've seen where some VOIP phone setups host their own dhcp server and it can cause issues.
