jamepc
May 04, 2021Aspirant
Orbi Backhaul Ethernet Switch
Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain l...
May 05, 2021Guru - Experienced User
NO, all RBS should be on same v104 FW.
40 series uses v2.6.x for it's model series while the 50 series is on v2.7.x. Though the recent version is v104 so this should be ok as v104 is most current for both series. You might turn this one OFF and just test the 50 series after you get the one RBS50 updated manually to v104.
jamepc
May 05, 2021Aspirant
Manually updated the one RBS50 to v104 ut unaboe to test wired backhaul until the weekend when network use is minimal.
Is having mixed FW versions a known issue for wired backhaul?
When I downloaded 2.7.2.104 I saw that they are also offering 2.6.1.40 as a download option. Is that because there's a lot of people experiencing issues with v104?
Thanks again,
Jamie
- CrimpOnMay 05, 2021Guru - Experienced User
jamepc wrote:When I downloaded 2.7.2.104 I saw that they are also offering 2.6.1.40 as a download option. Is that because there's a lot of people experiencing issues with v104?
I have never seen an explanation from Netgear for there being two firmware versions for the Orbi. At one time, there were separate versions clearly labeled for US and "world", hinting that some feature was available in one part of the world and not in the other. This started last summer (2020) about when Netgear began promoting their "Netgear Parental Controls" to replace Disney Circle.
Netgear provides almost zero practical information to customers. (opinion)
