ermannobonifazi
Mar 06, 2020Aspirant
Orbi backhaul goes to wired when should be wifi
My setup is one router + 2 satellite. On one of the satellite I have connected via wire a SKY Q Extender. If I connect the SKY Q when all the WI FI is up, an IP is assigned to the extender by my main...
Mar 06, 2020Guru - Experienced User
The RBR is reading the status as wired as the RBS is wired to this extender which correct, however is a odd configuration in the first place. I would use the extender after the RBS and not in between the RBR and RBS. The Sky Q would be the variable.
- ermannobonifaziMar 07, 2020Aspirant
Is not the RBR that is read as wired but the RBS where the extender is connected to acquire the IP, like it would be any other IP device.
- FURRYe38Mar 07, 2020Guru - Experienced User
Thats because its connected wired so it would read as a wired connection...
- ermannobonifaziMar 14, 2020Aspirant
Well is a wrong read. Is not wired to the RBR, just to another device that is the SKYQ Extender, no sense of reading the backhaul connection as wired. Just a bug.
