ermannobonifazi
Mar 06, 2020Aspirant
Orbi backhaul goes to wired when should be wifi
My setup is one router + 2 satellite. On one of the satellite I have connected via wire a SKY Q Extender. If I connect the SKY Q when all the WI FI is up, an IP is assigned to the extender by my main...
ermannobonifazi
Mar 07, 2020Aspirant
Is not the RBR that is read as wired but the RBS where the extender is connected to acquire the IP, like it would be any other IP device.
Mar 07, 2020Guru - Experienced User
Thats because its connected wired so it would read as a wired connection...
- ermannobonifaziMar 14, 2020Aspirant
Well is a wrong read. Is not wired to the RBR, just to another device that is the SKYQ Extender, no sense of reading the backhaul connection as wired. Just a bug.
- FURRYe38Mar 14, 2020Guru - Experienced User
Not a standard configuration if your using a extender with a RBS. Would not be a bug with Orbi. If an RBS is wired to an extender then it's communication is doing thru the wired, then to the extender. Orbi only reads status directly from the RBS or when the RBS is ethernet connected directly to the RBR or thru a switch. Even when the RBS is ehternet connecte, it will read as wired which is correct. Remove the extender between the RBR and RBS and you'll get correct status read from the RBS to the RBR.
However your configuration is working for you then don't worry about the status. Just it for what it does. Just know that Orbi doesn't fully support your configuration.
Good Luck.- ermannobonifaziMar 14, 2020AspirantMaybe I'm not clear. Gain the extended is a SkyQ extender. It just extend the SkyQ 5G (different than my WiFi) and not my WiFi managed with the Orbi. I need to connect the Sky Q to the Orbi to be able to get an io address from my lan to reach the other Multivision via IP. Again if I attach the SkyQ AFTER the RBS is booted The backhoul remain on wifi and my other RBS will daisy chain and all works but if the RBS for any reason restart the backhaul is marked as wired and the other RBS do not daisy chain.
