SoonerDoc
Nov 04, 2020Aspirant
Orbi Backhaul Issues
Saw several posts having a similar issue as I am without a solution I could find. Have RBR50 and two RBS satellites. Have modem going to ASUS router internet port. Have RBR50 router in AP...
Nov 04, 2020Guru - Experienced User
What CAT# cabling are you using between the RBR and RBS? CAT6 is recommended.
Does this happen if you just connect just 1 RBS to the back of the RBR, not both?
