SoonerDoc
Nov 04, 2020Aspirant
Orbi Backhaul Issues
Saw several posts having a similar issue as I am without a solution I could find. Have RBR50 and two RBS satellites. Have modem going to ASUS router internet port. Have RBR50 router in AP...
SoonerDoc
Cat 6 cabling
Asus RT-AC68P router
Orbis all on same firmware 2.7.1.60 for US
Cox gigablast internet on a Arris TM3402 modem
Orbi router (in AP mode) is V2. One satellite is V2 the other is V1.
Nov 04, 2020Guru - Experienced User
oes this happen if you just connect just 1 RBS to the back of the RBR, not both? Try each RBS one at a time to see if either one does same thing...
- SoonerDocNov 04, 2020AspirantHaven’t had a chance to test the 1 vs. 2 yet. Installed yesterday. Everything seemed to be working ok overnight, but when I had to reboot something this morning the issue started.
My issue sounds VERY similar to this guy’s problem from this thread:
https://community.netgear.com/t5/Orbi/Orbi-ethernet-backhaul-issues/m-p/1606398#M35843
B. If I plug the Orbi Satellite (RBS50) into a wired ethrnet cable to the switch, and turn it on; the whole network crashes..and stays crashed. Nothing, no local internet access and no WAN internet access.
C. IF, I power up the Orbi Satellite (RBS50) and let it connect via wifi to the main Orbi router, it works fine. Though, where it is located (some 65 feet in the opposite corner of my home) the wifi connection is usually 'poor'.
D. IF, I wait till the wifi connection is established between the satellite and main router, then plug in the wired ethernet to the satellite; the whole system works perfect.
E. IF, I screw up and plug in the wired ethernet too soon, the network crashes. to recover, I need to:
1. Unplug the Satellite (RBS50), wait awhile, plug it in, and wait till the solid white light comes on.
2. RESET the satellite (RBS50) holidng the reset down for 15 seconds or more
3. Let the satellite reboot, then reconnect via wifi to the main router (RBR50) and stabilize, then
4. Plug in the wired ethernet, and I am good again.
G. IF at ANY time, the satellite (RBS50) becomes unplugged, loses power, or loses the wired ethernet connectiong; the whole network crashes when it tries to reconnect. Then, I have to repeat steps 1 to 4 again.- FURRYe38Nov 04, 2020Guru - Experienced User
Do you have a LAN switch in between? I thought you didn't have a switch in the mix?
I haven't had a chance to test new FW out on mine. Last working FW that I know works for ethernet RBS and switches in the mix is v16.
