2bAlive
Dec 13, 2020Aspirant
Orbi backhaul simply not working, about to ditch it
About to trought out this very exspensive system as it simply never works. Got a simple system, one router one satalitle. The satelite is 90cm horizontally and 230cm (one floor) above the router...
CrimpOn
Dec 13, 2020Guru - Experienced User
I read this as a distance of about 9.3m. There is some other factor involved beside distance.Once the satellite has achieved a solid sync with the router and neither device has been moved, the sync should remain the same. Building materials should not "change" in a matter of hours. This is an RBS50 satellite. When it is powered on, does the "Ring Light" eventually glow blue for a minute or so?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
How is the backhaul status being reported:
- On the Orbi "app"?
- On the Orbi web interface?
Are there performance problems in addition to the status report?
How about an experiment:
- Temporarily move the satellite to the same room as the router.
- Plug it in and observe it for the rest of the day.
- Ring light turns blue and then goes off as it should?
- Does the backhaul status eventually go bad?
vajim
Dec 13, 2020Master
Does the Orbi system display different colors for the backhaul and the setup connection between router and sat?
