cjzielie
Feb 08, 2018Tutor
Orbi Best Connection setup
I just bought the 3 satellite system and set it up as a wireless system as i thought was supposed to, but i live in a newer house that has ethernet jacks in every room and was wondering what the bene...
t_k
Feb 09, 2018Luminary
cjzielie
If you have ethernet in your house already, you bought the wrong product! If you are still in your retun window, get a differnet product!
The selling big value of the Orbi's is that they have a very fast and dedicated wireless Access point to Access Point connection. It's a separate 4x4 Mu-MIMO radio that can only be used between devices, and it's why they are so expensive.
However, their device to device connection is also very unreliable and bug ridden, and still slower than a wired connection in any case. The only reason to use an Orbi is if you don't have ethernet already. If you do, there are cheaper and more reliable solutions.
Please, please, please don't listen to the fanboys and try to use the Orbi's. Over the next few months you'll end up trying to figure out why your connectivity keeps cutting out and why you keep having to restart your devices. See here.
If you're more tech savvy, go get the Unifi's, if not, go get the Eero's. In either case, they "just work", and are very fast with a wired backhaul.
cjzielie
Feb 09, 2018Tutor
I’m coming from a Nighthawk x10 that couldn’t cover my house and even added an x6 as A AP and that seemed crappy as well, I actually like the Orbi for my phone and etc laptops but want the fastest setup
