bashfulrobot
Apr 21, 2018Tutor
Orbi bit seeing new firmware updates in the admin interface
Hi there, Been having a few oddities with my router - so I keep checking the admin interface to see if there are updates. The system keeps reporting that there are no updates (see screenshot). St...
bashfulrobot
Apr 21, 2018Tutor
Is it acceptable to export the settings and import after the update? I'm just curious, but why do you need to do the factory reset?
Apr 21, 2018Guru - Experienced User
Due to all the various problems so far and each version of FW has produced various experiences with some users, and due to newer changes and such in this version of FW, Its highly recommneded to update FW and then reset to factory and set up from scratch. Yes, NG normally intends user to update and keep current configurations and they should persist and work well, however for this version of FW. Users are reporting that problems continued after updating however after doing a factory reset, the problems went away.
So it's just for this version that a factory reset and set up from scratch is needed. I believe NG will ensure the future updates will not need a reset and set up from scratch, unless it's needed to troubleshoot.
I recommend after updating and setting up from scratch, save off a new config to file for v2.1.3.4. Then you have a good back up for this version of FW.
- bashfulrobotApr 23, 2018TutorWhich version was that?
