rschap1
Jul 30, 2024Apprentice
Orbi BK43 AC2200 intermittent working/not working
 I have tried doing as much searching as I could prior to asking, but...  wondering if there is any advice or help possible.  I have seen quite a few similar questions and resolutions, but I am not te...
- Aug 15, 2024Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
rschap1
Aug 15, 2024Apprentice
Finally got a solution and fix to my woes.
After all of my searching and work, wasn't the router at fault at all.
I had swapped out to my old modem last week.
Swapped out to my old router.
And then on my Chromebook and phone, still saw internet on/off happening.
Sure looked like a Xfinity issue and not anything I could do on my end.
After MANY hours of chats and calls, finally got a technician out.
Was thinking that if their service couldn't be fixed/improved, and this was as good as it would get, then I would cancel since family and myself were used to relying on phones' hot spots.
But...
wife texted shortly after technician arrived that the coax from pole to our home was full of water.
Found splits in the insulation and it was full of water.
Replaced that section and all is better.
Wanted to share my fantastic tale 🙂
And once more say THANKS for the help given.
Showed me that there is a great deal that I do not know, but resources out there very helpful.
BIG THANKS !!!
Aug 15, 2024Guru - Experienced User
Enjoy. 📡
