crazymikeymike's avatar
Mar 03, 2020
orbi bkr 50
my orbi bkr 50 is connect to the wiffi
but when is look for it i will see orbi bkr 80 i need to enter a password
i don t know the password
 i thright the words
password
admin
enter nothing will not work
have reset  the orbi 2 times pare with other does work
light amber so that is goed
how can i get into the orbi
thright with the app en with pc
nothing works
1 Reply
  • FURRYe38's avatar
    Wire connect a PC to the router and factory reset the router using the back push pin button. Press the button for 15 seconds then release. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This will allow you to enter in a new SSID name and Password. I recommend entering in a SSID name of your choosing, something unique and custom.Don't use the default SSID name and PW. Can be anything. Something fun. Create a password for the wifi SSID name. This time write down all important information for safe keeping later on.
