Linabeena
May 15, 2019Follower
ORBI Blocking all sites & asking for pw
Since Netgear itself seems to have no answer to this, can anyone help me figure out how to fix the issue I have with my Orbi? When I am on the Orbi network and try to go to a website), I'm asked to enter a login and password.... for ANY and all websites... There was a thread that said this issue was solved (but it's not for me). A user said to go into the Orbi settings / security and add "https:" to allowed sites, but when I try to go into "Security" via the Orbi app on on login using my laptop, the only option that comes up under Security is an option to activate a trial to joing Netgear Armor. I've gone through the other settings.... I can't find any place to change allowances.
I have rebooted and I have set up as a new installation, twice. Nothing works. The wifi works, but when I use the Orbi network I still can't get to any websites.
Thanks!
1 Reply
Sort By
Is the Orbi system operating in Router or AP mode?Use a PC or laptop connected to the RBR and use a web browser to log in to the RBRs web page to make changes there.
Thanks!
