pmlo
Aug 17, 2020Aspirant
Orbi blocking devices after temporary network changes
Late last week there was a terrible thunderstorm which temporarily took down the fiber Internet connection (no signal in fiber modem). Since we're working from home these days, my workaround was to b...
Aug 17, 2020Guru - Experienced User
Yes walk thru a factory reset.
If your upstream host router uses 192.168.1.1 then the RBR will change to something different, maybe 10.something on the LAN side as to not conflicts with the host routers 1.1. address.
Or you can configure AP mode on the RBR.
pmlo
Aug 21, 2020Aspirant
Thanks, did a factory reset (after backing up the configuration), and now all works again after configuring the setup again.
- FURRYe38Aug 21, 2020Guru - Experienced User
Glad the reset worked to get the system working again. I would do a backup configuration to file for safe keeping. Helps save time if a reset is needed again later on down the road.
Please mark your thread as solved so other will know.
Enjoy. :smileywink:
pmlo wrote:Thanks, did a factory reset (after backing up the configuration), and now all works again after configuring the setup again.
