pmlo
Aug 17, 2020Aspirant
Orbi blocking devices after temporary network changes
Late last week there was a terrible thunderstorm which temporarily took down the fiber Internet connection (no signal in fiber modem). Since we're working from home these days, my workaround was to b...
Mstrbig
Aug 21, 2020Master
What is the TP-Link router connected to?
If possible, eliminate it.
You will more than likely, since the IP address changed on your Orbi router, need to reconfigure each device trying to reconnect. This is very common, especially if the devices are set to static IP.
You may have to reset the Orbi router if all else fails.
I doubt your network was hacked.
