jjoiv
Jun 01, 2019Aspirant
Orbi blocking location on Home Pod and iPad
It seems that the recent firmware update is preventing my iPad and Home Pod from knowing my location. For example, my iPad can’t figure out what time zone I am in, but if I go to my neighbor’s house,...
- Jun 21, 2019
My problem resolved itself after I moved. It must have had something to do with my former location.
schumaku
Jun 02, 2019Guru - Experienced User
jjoiv wrote:It seems that the recent firmware update is preventing my iPad and Home Pod from knowing my location. For example, my iPad can’t figure out what time zone I am in, but if I go to my neighbor’s house, it updates just fine.
This problem happens if you had installed a new router or wireless system and used a different network name (SSID). As long as no devices with GPS supported location connect to your network, and they allow location sharing, the cloud database will never learn where the network is connected.
Nothing a router, a firewall, an ISP, ... can do or block.
Same applies to Apple, Google, and other vendors maintaining a global location database.
jjoiv
Jun 02, 2019Aspirant
Thanks for your reply.
I am moving and disconned the Orbi sattelite and packed it. Would that constitute a change? The problem may have started then.
Could you clarify this sentence: " As long as no devices with GPS supported location connect to your network, and they allow location sharing, the cloud database will never learn where the network is connected." I have an iPhone with GPS connected. Do you mean the gps connected device is causing the cloud database not to learn?
- schumakuJun 02, 2019Guru - Experienced User
That's possible that either your iOS device is not enabled to provide and share the (GPS) location data e.g. to Apple.
I have no idea how log it does take until a new network name and location is picked up.
FMI: https://support.apple.com/en-us/HT203033
- jjoivJun 02, 2019Aspirant
Thanks. I think I would put this aside, wait until I move and see if the problem persists. I'll report back here if I learn anythng new.
